Ga door naar hoofdinhoud
Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745 Vragen Bekijk alle
Vraag afgerond
An external hard disc with 10.10 and internal with 10.11
There are certain applications which the makers refuse to give update with 10.11 for example aver t.v capture card why not have external hard disc with 10.10 as an o.s and the internal hard disc with 10 11 as the o.s is it technically possible to work please clarify thank you NARAYANAN LAKSHMANAN INDIA
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
While not often used, you can create multiple partitions under OS-X on your current HD. Then prep each partition with a different version of OS-X.
You will need to backup and restore your current partitions data once the partitions are created again. You'll need to delete the current partition and create new partitions. You'll also want to have a large enough drive to support all of these partitions, your current drive ever may not be large enough.
What you'll then do is leverage the boot manager by holding down the Option key when you restart your system to select the given partition you want to use.
Our test system has four partitions to test out application issues for the OS's we support. It's an older non-retina system with a 2TB drive.
Was dit antwoord nuttig?
Score 3
I don't see why I won't work. However, keep in mind that the system might be very slow or unresponsive if you boot from a external drive through USB 2.0. You should consider replacing your optical disc drive for a hard drive, this way you could use the SATA port.
Score 2
3 opmerkingen:
I would add here going with a FireWire external would be much faster than the USB 2 port.
door
I was going to mention it but it is very hard nowadays to find external storage with FireWire.
door
While many brick&morter stores have stopped stocking them on the shelf. You can get quite a few online. Here's one source we use: OWC FireWire External drives
door
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 58
