Ga door naar hoofdinhoud
First released in January of 2014, the Pebble Steel is a steel-bodied Smartwatch from Pebble Technology Corporation.
7 Vragen Bekijk alle
Why won't my Pebble Steel turn on?
This morning I tried to turn on my Pebble and nothing happened. I tried connecting it to the charger and waiting a few hours, but it wouldn't power on at all and still won't. What should I do?
Is dit een goede vraag?
Score 1
1 Opmerking
My Pebble watch also got the same problem. I tried many times to charge or follow the instruction as per a few people gave it to me but nothing is working. it's very disappointing, Pebble has stop supporting and now I don't understand where to go and what to do to start my Pebble watch. Sad feeling with the pebble
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Make sure that your charger is plugged in and working properly. The problem could be that your watch needs charging and the charger is broken or not connecting right. Try cleaning the contact points on the charger and the device with rubbing alcohol.
Also, the troubleshooting page might help.
Was dit antwoord nuttig?
Score 4
Boa Noite
Venho por este meio pedir ajuda tenho um Pabble Stell
fiz restaurar as defenícões e não consigo preciso de
toda a vossa ajuda.
Obrigado
Carlos Veloso
Voeg je antwoord toe
Jessica Johnson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 14
Altijd: 4,109
