Ga door naar hoofdinhoud
Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745 Vragen Bekijk alle
Vraag afgerond
Stripped screw head on back cover
Help! I am trying to replace the battery on my Macbook Pro 13 Unibody Mid 2009 battery. I was successful on removing all of the screws except 1 on the top left corner (its a longer screw). I tried many different screw drivers including Phillips #00. It won't budge and now I think I stripped the screw head!! Its so tight there is no way I can get pliers/tweezers or anything to loosen it. What can I do to get that screw out now that it's stripped???
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
small drill bit and drill the center of the head out and it will fall off use needle nose to remove the remaining part of the screw after taking off the bottem
Was dit antwoord nuttig?
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 159
