Ga door naar hoofdinhoud
First released in January of 2014, the Pebble Steel is a steel-bodied Smartwatch from Pebble Technology Corporation.
7 Vragen Bekijk alle
My Pebble steel isn't vibrating when I receive a new notification
My Pebble Steel watch is not vibrating when I receive a new notification. I can still see when I get a notification because it pops up on the screen but I don't feel the vibration. I have made sure that the settings on my phone and watch are both set to vibrate for a new notification. What else can I do?
Is dit een goede vraag?
Score 4
1 Opmerking
that fixed the problem. thanx.
door
Voeg een opmerking toe
6 Antwoorden
Gekozen oplossing
Also, try visiting the troubleshooting page for more help.
Was dit antwoord nuttig?
Score 6
Het nuttigste antwoord
Mine was in Quiet Mode. You can change this in the settings. You can also change this by holding down the button on the left side of the watch while at the watch face.
Score 18
12 opmerkingen:
Worked for me, i feel so stupid now
door
Mine was not working either, Supid #2! Thanks!!!
door
Wow! Thanks! *face palm*
door
Add me to the dummy list! Thanks for the help
door
Not working. Howwwee
door
7 commentaren meer tonen
Try resetting the watch.
Score 3
3 opmerkingen:
I reset it and it only vibrates on phone calls.
door
I reset mine nothing, no vibrating at all. I'll try again.
door
Though it works, feels over kill. Try the quiet mode
door
No solution worked. No vibration at all even after hard reset
Score 1
My pebble steel started to vibrate again, after android wear app was removed
2 opmerkingen:
I had same problem after installing Android Wear. I took 'belt and braces' approach and deleted AW app and also did a factory reset on the watch and signed in with a new account to make sure I really was back to 'factory settings'. I chose this boots-and-all approach as I had previously also installed a new watchface (Beacon) which screwed the watrch up completely and caused it to reboot at random times and I wanted to make sure I had totally got rid of it.
door
Thanks. I m on the top of the dummy list!!
door
Just discovered this:
Notifications will appear, but not vibrate, when the Pebble Time is charging.
Voeg je antwoord toe
Orlandria Heggs zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 15,679
