Ga door naar hoofdinhoud
A 10.1 inch Samsung tablet computer with a 1.4 GHz processor, 1280x800 pixel LCD, and 149 ppi multi-touch display. The model number of the device is GT-N8013ZW. Released August 2012, repair of this device is straightforward.
127 Vragen Bekijk alle
Why won't my tablet charge?
My GT n8010 Samsung note says its charging but it isn't. It is loosing power while it is plugged into the charger. The battery indicator says it is charging but the battery power doesn't change. I haven't tried a new cord yet, I wanted to first see if anyone else had this problem, and had a quick solution before I went out and bought another cable and charge unit.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
eccentricdaught this could be caused by either your battery or your charging port flex. Start with the replacement of the less expensive part.
Was dit antwoord nuttig?
Voeg je antwoord toe
Eccentric Daughter zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 5
Altijd: 650
