Ga door naar hoofdinhoud
Repair information for the 4th generation iPad. Released November 2, 2012. Model numbers: A1458, A1459, and A1460.
408 Vragen Bekijk alle
Vraag afgerond
Replaced Digitizer and LCD. LCD not working
broken digitizer. LCD working. Replaced digitizer. LCD not working. noticed that i damaged ribbon cable connection. Ordered and replaced LCD. LCD still not working. IPAD is on. Is detected by find my iphone and plays sound. have tried hard reset. Successfully shut down (not seen by find my iPhone). turned back on (seen again by find my iPhone). Next suggestion.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
If you didn't power off the iPad when working on it , it is likely that you blew the lcd backlight filters when you plugged or unplugged the lcd. This will require a board level repair.
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
"board level repair"?
i presume it means i ruined the mother board
door
Thank you for your answer, by the way!!
door
I wouldn't say ruined, but it will need some micro soldering.
door
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 85
