Ga door naar hoofdinhoud
In August 2000, the ninth-generation Corolla was introduced in Japan, with edgier styling and more technology to bring the nameplate into the 21st century.
20 Vragen Bekijk alle
My car is running on 3 cylinders.
About 10 months ago the radiator of my car was replaced. The car was overheating periodically. I thought it was the thermostat, but the mechanic did not replace this. The car continued to get hot periodically. I was informed today that the car is running on 3 cylinders. The car is a 2003 with 200k+
Miles. Is it worth it to repair?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Take it to an AutoZone and get a free computer readout so you know what the problem is.
Was dit antwoord nuttig?
Score 2
Het nuttigste antwoord
First, I would like to know what brought them to that conclusion?
Score 2
2 opmerkingen:
So many questions could be asked on this situation. Did the mechanic give you any feed back? Is the 4 th cylinder locked up? Have you hooked up a code reader to get the check engine codes? Do you get your fluids replaced regularly? Did you recently have a radiator service?
door
I concur with the above request for more questions. Can you scan their repair estimate into here? Block out any personal info, of course. One bad cylinder can be many things-- the real question is what is the COST of the repair? That's the REAL determining factor about fixing it or not.
door
Voeg je antwoord toe
Maggie zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 1,707
