Ga door naar hoofdinhoud
The Asus X555L is a low budget laptop that came out in May of 2015. The model depicted in these guides is X555LA-SI305041, an Intel Core i3 laptop designed to be affordable for consumers. Similar model numbers: X555LB, X555LD, X555LF, X555LI, X555LJ, X555LN, and X555LP
Vraag afgerond
How do I disable the trackpad?
I'm looking to disable the trackpad on my laptop and can't figure out how to do it. Anyone know how?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
For most ASUS laptops, hold the "fn" button then press the "f9" button.
If the "f9" button did not disable the trackpad, then resort to disabling it through device manger under system.
Was dit antwoord nuttig?
Score 1
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 272
