Ga door naar hoofdinhoud
7.1 megapixel camera by Canon, model SD750.
9 Vragen Bekijk alle
Why does my camera say ,"No Memory Card?"
Every time I attempt to use my SD750, I get an alert saying ,"No Memory Card," even though there is a card inserted in the slot. There is nothing wrong with the card. Any suggestions? Thanks...M.
Is dit een goede vraag?
6 opmerkingen
No memory card in my camera
door
Use the camera to reformat the card.
door
What do you do when the camera says "No Memory Card" and does not show "format" as an option in the menu?
door
When it says no card what will you firmat bro
door
My camera doesn't turn on guess it could be the battery, is there a way to check if battery is good.
door
1 commentaar meer tonen
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Guessing it's not reading the card. Try cleaning it with some isopropyl alcohol. 90 proof is usually what I use
Was dit antwoord nuttig?
Score 1
4 opmerkingen:
Did you get my last response?
door
I guess not. All I got was that one
door
I tried cleaning mine, but no luck. I've tried 3 different memory cards and get the same answer. No memory card. Hmmm? Is it worth repairing or just get a new camera. My phone has just as good of megapixels. Any suggestions? Thanks
door
Well, did you try cleaning the contacts with 90% isopropyl alcohol, or did you just try different cards?
door
Voeg je antwoord toe
mesarey zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 22
Altijd: 4,982
