Ga door naar hoofdinhoud
The Nokia N70 It is equipped with a 2 megapixel camera with built-in flash, a front VGA camera to allow video calling, FM radio, and Bluetooth.
9 Vragen Bekijk alle
Why is not my battery charging connecting 24 hour
why is not my battery charging connecting 24 hour
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Does the phone indicate its charging? Are you using an OEM charger? Battery as well?
Was dit antwoord nuttig?
Score 2
1 Opmerking:
It could be because your battery is broken, mostly because it wasnt from the original one. Your charger can be also a problem, try to hold it straight, if the connector always wiggles. You can also try your other chargers. I also have that wiggling problem, but i have another charger that didnt.
Voeg je antwoord toe
lakshmikanthareddy zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 1,808
