Ga door naar hoofdinhoud
Een gameconsole voor de televisie, geproduceerd door Sony Computer Entertainment, ook bekend als de PS4. Voor het eerst aangekondigd op 20 februari 2013 en gelanceerd op 15 november, 2013.
ps4 update bootloop problem.
I bought the Playstation off cl knowing it had a problem. Keeps failing updates. Ive replaced the hdd with ssd, and installed software with several usb drives. i also tried the software its on 2.04 and every thing between current 3.00. Before I have it repaired was hoping there is a fix. I was thinking maybe pulling the cmos battery. the error code is su-30631-3. model cuh-1001a.
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
6 Antwoorden
You have to upload the full system software not just the update
https://www.playstation.com/en-us/suppor... (scroll to the very bottom of the page)
apologies if you've already done this - but i made that mistake once
Was dit antwoord nuttig?
1 Opmerking:
I used the full 800mb software file of several versions.
door
I have the same Problems. Anyone a solution?
I have similar problem since my son tried to install the update a few weeks ago. we've tried installing the full version oo and although it appered top work, a couple of days later the PS4 just keeps rebooting and saying you need to install the system software.
Will try contacting Sony support, but if anyone has any answers as to why an otherwise perfectly working machine should just fail like this following update, I'd be grateful - so will my son!
TIA
Same problem and no solution.
Meme probleme et pas de solution de sony
Has anyone found a solution? Same problem here:(
1 Opmerking:
Have you solved the problem? Thanks
door
In reading online this particular error is caused by the NOR Flash being corrupted. The onle fix listed i have read is to unsolder the flash and decode the dumpfiles.
Voeg je antwoord toe
Kyle Simmons zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 3,700
