Ga door naar hoofdinhoud
The Western Digital My Passport Ultra is a USB 3.0 portable storage device with capacities from 500 GB up to 5 TB.
37 Vragen Bekijk alle
Why are these hard drives getting corrupted?
I have several of these "My Passport" Western Digital drives. One was causing problems (not mounting, etc) and disk utility couldn't repair it. So I backed it up to a new hard drive (same type - I have a number of these). Now, a couple of months later, I'm having the same problem with the new drive. Is it possible that there are particular files on the drive that are causing this? How would I find out? I don't want to keep having the same issue if I buy yet another drive to back this same data up on.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
When i have problems with drives I usually reformat the drive and select the "write zeros" option so it will map out any bad blocks on the drive.
Was dit antwoord nuttig?
Score 1
Yep, I agree with mayer. To prevent these issues in the future, make sure that you are properly ejecting your drives, shutting down your laptop/computer properly, and keeping the external in a place where it won't get banged around.
If the externals are still having problems after formatting/proper usage, you might want to contact Western Digital for their warranty, which I believe is 2-3 years per HDD.
Score 1
Make sure they are getting enough power,thats normaly the no 1 problem.make sure you use a powered hub,try not to use the double usb lead that comes with them,they realy dont source more power to be honest,they are a wast of time,make sure the usb lead is of good quality and nice and thick too.
Score 1
Voeg je antwoord toe
jzbmom zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 13
Altijd: 9,424
