Ga door naar hoofdinhoud
The iView SupraPad 776TPCII is a 7" touch screen Android tablet.
Why is my tablet running so slow?
Every time I try running more than one or two apps at a time, my tablet slows down and eventually stops working.
Is dit een goede vraag?
Score 2
3 opmerkingen
I had an i View it was the BIGGEST piece of junk I ever bought. The poor thing took flying lessons across the room and I went and got a different brand. NEVER again to View.
door
Ican't used Google login on anything on this tablet I try to get on line can not I had this tablet for two years never been able to use it like the other one I have
door
Going through the same issues..purchased from Walmart for xmas and it has never worked. Nothing loads at all. Not even the time stays correct. Is there a repair shop or should I just take it as a lose.
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Running too many apps at the same time or using the tablet while it's updating software may freeze up the device. Check to see if any unnecessary applications are open or if updates are currently being installed to the device. Short term speed can be improved by either closing these extra apps or simply letting any downloads finish before normal use.
If your tablet is still slow, this may be caused by a processor unsuited to the high demands being placed on it. Trade out the factory installed processor with one rated higher for performance and you will see an increase in speed from your tablet.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
I want a replacement. Nothing can be this Bad
door
I have the same one and it is GARBAGE. Freezes up and shuts down and now it won't even turn on. I'm about ready to give it flying lessons across the room lol. Just patiently waiting for my new Tablet to get here. I know it can't be any worse then this one.
door
What helped me was disabling google and getting Mozilla Firefox. Also get rif of apps that you don't use. Works faster now.
Voeg je antwoord toe
Jonathan Fenimore zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 21
Altijd: 3,103
