Why is my MacBook Freezing up?
At random times my mid 2012 13 inch MacBook Pro will freeze up, with 5 sets of dual horizontal lines about an inch and half wide showing. If I'm plugged in and unplug, the computer shuts down immediately. If I'm running on battery power, I have to close the top and it takes about ten to twelve seconds for it to shut down. It makes a static-y clicking/popping sound for that ten seconds, then shuts off. I can then restart.
This happens at apparently random times. I'm not hitting the track pad or any specific key, and it has happened while I'm not even touching the unit. I have a photo of the screen if that might help anyone diagnose the issue. It is starting to happen more often now. Any ideas?
Is dit een goede vraag?
6 opmerkingen
By chance did you get your system wet at some point? I think you'll need to pop open the bottom cover and make a good inspection.
door Dan
It has not gotten wet at all, that I can recall. I did max out the ram about a year ago. Makes me wonder if I left a cable loose or something.
door James Sunny Jim White
Did you get a chance to pop the bottom cover to take a good look?
door Dan
I think I will reseat the ram and see if that helps. I will let you know!
did it happen again after you reseated your ram? I have the same problem.
door lamyinfung
1 commentaar meer tonen
