Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Vragen Bekijk alle
Vraag afgerond
How to reboot my phone
My screen froze and my power button doesn't work how can I fix it
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
Without the power button you might have to wait for the battery to die
Was dit antwoord nuttig?
Score 1
if you are happy to open your phone you can disconnect the battery
Score 1
If the power button is damaged you have no way of doing this without taking apart the phone. Follow this guide, all you need to do is remove the battery connection then reconnect it again, plug it into the charger and it will boot up.
The phone becomes quite hard to operate when the On / Off button is not working so get that repaired as soon as possible
Best of luck
Regards
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 104
