Ga door naar hoofdinhoud
The modern, current Toyota Tacoma - fully updated.
17 Vragen Bekijk alle
How to change running light bulbs
Change burned light bulb. How to access old bulb to put in new.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Are you referring to the amber turn signal bulb or the small bulb in the corner of the headlight? If so both of those bulbs can be easily accessed if you open the hood and reach around the backside of the headlight. There you can twist the socket to the right and pull the bulb out and replace them without removing the headlight entirely.
Turn Signal/Running Light Bulb Type: 4157NA
Small Side Marker Bulb Type: T10
Was dit antwoord nuttig?
1 Opmerking:
You can pry the plug off easily using a screwdriver between it and the housing. The bulb holder is a different story in it can be just a hard to turn object without a size a socket can cover. Careful with pliers to not break the plastic.
door
Voeg je antwoord toe
Tim Blackwood zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 79
Altijd: 2,818
