Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Vragen Bekijk alle
Vraag afgerond
Stuck on Activation Screen
Hi,
I have a Iphone 5s and the problem was it was always on searching wether there is Sim or not, and i was using it like a IPOD.
A day before my lil bro mistakenly done a factory reset with all content settings, and now its stuck on activation screen, like there is no carrier sim inside and its after connecting wifi it takes some times and say there is some problem with Apple server.
Any solution ?
Thanks
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
solution #1
make sure you’re connected to a functioning wi-fi network that is able to connect to the broader internet. Sometimes a very restrictive router can be the culprit and may block the iPhone from attempting to reach Apple’s activation servers, so simply joining a functioning network does the trick, allowing the iPhone to communicate with the outside world and skipping the screen.
Solution #2
You can bypass Activation errors by using any original carrier SIM card, it doesn’t need to be for an active account or a valid phone number – so even if you or a coworker has an old one sitting around in an office desk somewhere, it will work to pass activation. It just needs to contact the activation server, verify that it’s good (ie: not stolen) and then you’re good to go.
Was dit antwoord nuttig?
1 Opmerking:
First of all , thanks for the reply, i already checked these answers before .
1) . Wifi is working , but as its no getting my sim card might be hardware issuee so its not working.
2) . Problem is that no sim card is working.
Thanks
door
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 1,859
