Ga door naar hoofdinhoud
Repair information on hard drives or hard disks. Hard drives are magnetic data storage devices. They are used in most desktop, laptop, and server due to their low cost and high data density.
143 Vragen Bekijk alle
Suddenly I can't save files on my external hard drive anymore!
I have Sony external hard drive HD-E2, and it was working fine; I could save files on it and copy files from it. But then, suddenly, I was only able to read from it. I find it odd since it was working great for almost 4 months.
My laptop is MacBook Pro.
However I started to have this problem after upgrading to El Capitan MacOS.
Could this be somehow related or relevant to the problem?
How to fix this problem?
Is dit een goede vraag?
Score 3
3 opmerkingen
I have a WD Passport HD with 4TB. When I bought it, I partitioned it, so that I could use one partition for Time machine, and the other for extra files. Now the Time Machine partition is writable, but the other partition is readable only. I cannot copy files onto it anymore. It may be due to an upgrade in my OS. I’m running High Sierra. I’ve tried to change permissions in the INFO section of the partition, but everything is greyed out. How can I get read and write permissions without having to reformat the whole HD? Thanks for your help.
door
I have an intel tower that has a write disk drive. I have put a disk and I am unable to save files to the cd drive.
door
Yesterday my seagate 4T portable had strange sound like engine metal scratching , today sudden death, so bad seagate quality . i will never buy seagate in my life
After scan disk successfully, some movies file still cannot copy out
maybe due to bad sectors or 1 of the pin heads dead
this seagate 4T portable is 3 months ago given by seagate recovery lab
door
Voeg een opmerking toe
6 Antwoorden
Gekozen oplossing
1. Shot in the dark - try running Disk Utilities and repair the permissions.
2. Click once on the drive, go under File to "get info" and see if you have Write permission.
Was dit antwoord nuttig?
Score 3
8 opmerkingen:
My Toshiba Portable is having the same problem after my recent upgrade. It is showing that I do not have write permission. Is there a way to change it so that I can write again?
door
Cj I'm strictly Mac. Please ask a new question and tell what machine you are using and what OS.
door
I'm sorry, I have a macbook pro.
door
I'm on windows 10 and I don't have admin permission to change that. I can't even change myself to admin.
door
door
3 commentaren meer tonen
https://www.boxaid.com/blog/fix-read-ext...
For those still struggling: I have a Seagate External HD that was never partitioned for Mac as I use it to share files between Windows and Apple computers. Suddenly I wasn't able to write/copy files to the HD (maybe due to upgrades of my MacOS?). Followed the advice of this website and downloaded the recommended helper for Seagate. Very helpful.
Score 1
The best solution for this is reformatting your external hard disk or check for errors in hard drive. Some times you received permission error, and you just need to ignore permissions.
Score 1
1 Opmerking:
What if i can't afford to lose my files??
door
I could not do either. It says under permission it has read and write. But just above it says you can only read. I used this disk on mac only for the last two years.
Score 1
2 opmerkingen:
I have the exact situation as bhandr
door
I have the same situation did you ever solve this?
door
Mayer was correct!! i I right clicked on the drive from the desktop and choose “get info”. you will need to unlock the drive located on the bottom right hand corner. put in your password and put a check next to “ignore ownership on this volume.” lock it back up and try it. .it totally worked for me.
Score 1
2 opmerkingen:
Not clear. Bottom right corner of which window.
door
I didn't find the above mentioned option anyhwere. Help
door
Anyone reading this, I did a combination of things that finally worked. Partitioned the drive in half (so my saved stuff was left alone.) Formatted the new partition by “deleting” it. This created a new icon on the desktop to the newly formatted partition. Double-clicked on the new drive. Select “get info” (upper right button), then I unlocked to “ignore ownership.”
Finally I went back to the application that was not allowing me to save to that specific location, and I hit “search" or “find” and then typed in the name of the partition I gave it (default name is “untitled” but it will be whatever you name it above, or how it appears on your desktop). Then the application finally found it. Lastly, clicked on it, and then it allowed me to save to the External drive. I am currently copying files, god bless it.
Voeg je antwoord toe
Moath zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 39
Afgelopen 30 dagen: 137
Altijd: 62,331
