Ga door naar hoofdinhoud
Zakelijke desktopcomputer geproduceerd door HP in 2007. Green PC-gecertificeerd / Intel Core 2 Duo-processor
will it work with an intel slb6b processor?
have 2 gb of ram 159gb hdd wirh a intel dual core 1.80 processor and it hangs or stalls when using propresenter 5
Is dit een goede vraag?
3 opmerkingen:
the intel processor is 2.66 ghz / 6m /1333 /05A.core 2 quad core
door
What are the model specifications on your current processor? You can check the socket of the compare those specs with those Intel® Core™2 Quad Processor Q9400S against what you have as a starting/reference point.
door
Most likely, but still possibly not. The motherboard may not support the specific processor, but it is worth a try. The socket is the same. But you may need to install a new heatsink for the new CPU. It has a higher Thermal Design Power.
Check this link if you need help installing a CPU:
HP rp5700 Central Processing Unit (CPU) vervangen
door
Voeg een opmerking toe
1 Antwoord
Filteren op:
The rp5700 only supports CPUs with a 1066 MHz FSB. The Q9400 (SLB6B) has a 1333 MHz FSB. The fastest CPU supported is a Core 2 Duo E7400.
Was dit antwoord nuttig?
Voeg je antwoord toe
Aeryn TwoFeathers zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 32
Altijd: 649
