Can I increase hard drive capacity?
Can I increase the storage capacity of the hard drive? The initial capacity seems too small for what I need and would like to increase it.
Is dit een goede vraag?
The ElitePad comes with 2Gb of RAM and Hard drive sizes vary from 32/64 Gb. If more space is needed it is compatible to external hard drives that can be connected to USB ports on the docking stations or the detachable keyboard.
Was dit antwoord nuttig?
You could use apps like Google Drive and Drop Box to store and access your information on a cloud system. You "expand" your memory storage and are able to access that info on other devices!
I have a 128 GB microSD card in my Elitepad 900 G1, it seems to work OK
Russ
The Elitepad has a microsd slot hidden under the cover symmetrical to the volume buttons. put a large microsd in there and you are away
No its built into the motherboard and you have a SD card slot that can go up to 64gb that's it.
Actually I used 128 MG cards n problem and reliably filled them up.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 21
Altijd: 3,689
1 Opmerking
The eidt bade work when concted to charching divice but not work when remove from it
door almammory
