Ga door naar hoofdinhoud
OnePlus' second entry into the Android phone market, the OnePlus 2, was released on August 11th 2015.
49 Vragen Bekijk alle
Volume button is stuck in the up position.
Just as the title says, my volume button is stuck in the up position. This means I cannot power up my phone without it going into fastboot mode, thus rendering my phone useless. I did not bump or hit the phone prior to this, my phone was just in my pocket the whole day. Any ideas on the fix?
Is dit een goede vraag?
Score 6
Voeg een opmerking toe
1 Antwoord
I have the same issue! I must have bumped my phone against a surface at some point and now the volume button is permanently pressed. Fortunately, my phone is powered on so i can still use it but i cant un press the button. This happened to my one plus one and when it did, i unscrewed the device and used pliers to straighten the "bar" which is the volume controller and then re-assembled the phone. I cant find any video or tutorial on how to unscrew the one plus two however..... :(
Was dit antwoord nuttig?
Voeg je antwoord toe
davidahannon zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 1,975
