Ga door naar hoofdinhoud
Home button replacement problem
Hello,
I am trying to replace the glass from my ipod touch. I have the front panel out and the glass from the plastic surroundings and I am ready to put the new glass on it. Now there is a small question. The glue that I got with my glass, also covers the place of the home button. Is it a problem that my home button is glued to the platic frame, so will there still be connection? Or do I need to take of the glue from the home button?
Thanks in advance
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
why is the home button glued to the frame??
maybe i didn't got it right - but when you glue it to the frame - how should it work??????
so, yes - remove the glue from the home button
Was dit antwoord nuttig?
maybe you had a cover on the glass that has to be removed...
Voeg je antwoord toe
Niek Bronswijk zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,415
