Ga door naar hoofdinhoud
Released in April 2013, identified by model GP-002(fx).
Why is my phone dying so fast?
I have to charge my phone multiple times per day, but the battery used to last a lot longer. The battery also drains quickly even when I'm not using it.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
If your Keon is having trouble holding a charge your phone may be over working itself if you have too many apps running or too much data on the phone. Some things you can do to improve battery life are to remove unused apps and delete unused data. Adjusting setting such as brightness and mobile data can also help improve battery life. If none of those things help, your battery may worn out and need to be replaced.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Bryan Bittner zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 56
Altijd: 561
