Ga door naar hoofdinhoud
Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Vragen Bekijk alle
Vraag afgerond
Battery not charging after replacement
Hi. I have changed my battery with a new one following the guide, and after boot it loaded normally with low battery, after a while it shut down showing the plug in connector screen, and connecting it had no effect. Now it doesn't power up, tried several cables, computer and wall charger, etc.
I have also tried to disconnect the battery cable and connecting an external battery to the device with no luck. Bets: battery, dust or lightning connector?
Thank you
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
check to recharge your battery outside your phone using an external power supply , cause charging battery would not start (by software) if the battery storage less than a certain value !!!
Was dit antwoord nuttig?
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 94
