Ga door naar hoofdinhoud
Repair guides and support for riding, or ride-on, mowers, also known as lawn tractors, of all types used in tending large tracts of land.
Mower deck not engaging
i have husqvarna model EZ5426BI mower deck will not engage. Just had the mower serviced than was mowing the lawn and IZT belt broke and was replaced and found the Deck belt had crack so I replaced it and now the deck will not engage
Is dit een goede vraag?
1 Opmerking:
Generally speaking, when it works until you fix it, you should go back and double check the work you did. Probably got the deck belt routed wrong - go back and make sure you are on the right side of every guide and pulley.
door
Voeg een opmerking toe
1 Antwoord
You might want to check you ingagement lever and see if the cord that goes from the lever to your deck is broke
Was dit antwoord nuttig?
Voeg je antwoord toe
Bhagwanji Gosai zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 121
