Ga door naar hoofdinhoud
The Samsung Galaxy Ace is a low-end, slate-format Android device released by Samsung on February 2011. Identifiable by model numbers GT-S5830(i, B, C, L).
31 Vragen Bekijk alle
phone not turning on
i was installing new firmware which was installed completely. but when i rebooted my device it doesnt start again. no button or combinations are working. have tried charging for long time and even reinserting my battery. pls help me
device is samsung galaxy ace gt-s5830
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
5 Antwoorden
Het nuttigste antwoord
Hello Anirudh Akash,
its seems to be firmware corrupted on your phone. check whether it detect by from PC, if PC detecting your phone or installing drivers you can install kies and try to update firmware via kies
Was dit antwoord nuttig?
Score 2
it is not powering up and it is nor detected by pc or by kies and neither by odin.. it all dead.. nothing is working.... its not even going into download mode or recovery mode.
Score 1
The mobile is self-charging without connecting the power supply
Score 1
have you tried replacing the battery?
if not that then maybe its a screen or motherboard problem
I have the exact same problem. I gave up on the phone along time ago, and i have realized both of us have done, is bricking the phone completly. i cannot find a solution either, but i dont think you can fix it.
Voeg je antwoord toe
Anirudh Akash zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 6
Altijd: 1,171
