Ga door naar hoofdinhoud
Reparatiehandleidingen en ondersteuning voor auto's en vrachtwagens geproduceerd door Chevrolet.
1367 Vragen Bekijk alle
key stuck in ignition of old truck
The ignition key mechanism won't turn off or release key. I have been removing fuse to shut her down... It is stuck in "on." Turning of the steering wheel to relieve locking does not seem to help.
Any suggestions would be appreciated
Scott
Is dit een goede vraag?
2 opmerkingen:
Have 88 gmc truck key stuck in ignition in on position and won’t come out tried everything disconnected battery to start power
door
I've had the same thing happen, I've had luck twisting the key partially int the start position the back to off. the permanent solution is a new ignition cylinder
door
Voeg een opmerking toe
3 Antwoorden
Depending on the year there is a small hole which you stick a paper clip into next to the key hole. Pushing the clip in and turning the lock set toward accessory will allow the whole lock set to be removed.
Was dit antwoord nuttig?
1 Opmerking:
Then you can push the key out from the back side of the lock.
door
Some old cars with the key on the steering column would ‘lock’ the key in if the wheels were turn all the way to the left or right, such as when parallel parking. You had to pull the steering wheel real hard in the opposite direction while simultaneously turning the ignition.
1 Opmerking:
Have 88 gmc truck wheels r straight and turn and key will not turn off
door
Do as Frankie advised you, I had the same problem a few years ago and that did the trick.
2 opmerkingen:
My "new" 88 GMC C1500 just started doing this. Will the steering wheel yank work forever or do I need to replace ignition or...?
door
How do you fix that on 1998 silverado c1500 have to turn wheel Wich is hard all the way to the left to turn over the key and when you do hearing clicks
door
Voeg je antwoord toe
redhare zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 35
Afgelopen 30 dagen: 143
Altijd: 13,725
