Ga door naar hoofdinhoud
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
20 Vragen Bekijk alle
Kenmore 110 will not power on.
Washing machine will not turn on, no selections will work. GFCI power outlet was tripped, I reset the outlet and it does have power. Tried different outlet, same result.
Is there a reset button in washer or any fuses. Made sure lid was fully closed.
Is dit een goede vraag?
Score 6
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
If your Kenmore 110 Series Washing Machine refuses to turn on, see the Kenmore 110 Series Washing Machine Won’t Turn On problem page for possible causes and solutions.
Reading around it doesn't look like there are fuses that need to be replaced or some reset switch.
I haven't had experience with this specific washing machine, but there are some forum posts out there that look like they have had the same problem. Here's some instructions that look useful.
Good Luck!
Was dit antwoord nuttig?
Score 1
your forums sucks donkey dicks
Voeg je antwoord toe
Bob Johansen zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 24
Altijd: 4,141
