Ga door naar hoofdinhoud
De Xbox draadloze controller 7MN-0001, vervaardigd door Microsoft Corporation, is de meest gebruikte controller voor Xbox-spelcomputers en kan ook in combinatie met pc's worden gebruikt.
My triggers and (a) button dont work
hey i was doing some diy mods to my xbox one controller (i changed the d-pad triggers bummers and joy sicks to white) and now my trigger either are unresponsive or are shooting and aiming non stop. also my (a) button only works in game when i go to the xbox menu or homescreen i have to click the button 3 times to get it to work.
Is dit een goede vraag?
1 Opmerking:
bump? i still have this problem
door
Voeg een opmerking toe
3 Antwoorden
hey Im having the EXACT same problem (even the xbox menu/in game 'A' button issue), bumping for some help.
Was dit antwoord nuttig?
1 Opmerking:
have you found anything out?
door
I have the same problem. What happened was I accidentally scratched the magnetic sensor for the triggers and now I have to order a whole new mother board and I don't know about you a button....
2 opmerkingen:
can i ask were you bought the new board from ? and it is only the one board or are you buying both
door
Well I bought it on this web sight but you can probably find it cheaper if you do some research but I only needed the thumb stick mother board or the bottom to fix the trigger but if your a button isn't working too your best bet is to buy a new controller because to fix that you need the other mother board...
door
I have the same problem, i bought the controller new (the warranity expires 2 days after) the left and right triggers are not tight but they keep aiming and firing
Voeg je antwoord toe
killerbunnies KB zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 36
Altijd: 1,284
