Ga door naar hoofdinhoud
De huidige iPod Touch lijn bevat 6 verschillende generaties.
2619 Vragen Bekijk alle
What can I do if I forget my password?
Someone stole my ipod and changed the password when i found it i didn't know the password so i need help.
Is dit een goede vraag?
Voeg een opmerking toe
6 Antwoorden
Gekozen oplossing
You can do it, but it requires the iPod touch to be reset, hopefully you have synced it recently with iTunes before it was stolen?
Ok so connect your iPod to iTunes
Hold power button and Home button (circle button) at the same time, maybe around 8 to 10 seconds.
It should now reboot (screen will go off), release JUST the power button, keep home button held down.
iTunes will say it has found an iPod in recovery mode.
Now just restore your iPod with your iTunes.
It will wipe everything first, then put it back on.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Dude. thank ou so much.
door
OMG it will delete all my photos!!!
door
it better to get restored.
Score 1
Can’t access your iPod? To reset a lost iPod password, follow these instructions.
1. Plug your iPod into your computer.
2. Make sure you have the latest version of iTunes.
3. If necessary, back up all your music. Though you may think that this is impossible with a locked iPod, the screen lock only protects the iPod interface itself; it doesn’t protect/encrypt any of the data inside, meaning you can still access it from your computer.
4. Restore your iPod. This will clear its contents and restore all factory settings.
5. Re-sync your iPod and apply a new password.
More from: http://www.wikihow.com/Reset-a-Lost-iPod...
it doesn't work!!
thank you man you are the best
Well, i just have the same experience with you. forgetting the passcode of a iDevice, but my iDevice is an iPad. But i think maybe the way to solve the problem is similiar, so i recommend you to refer to https://www.isunshare.com/iphone-ipad/re....
Hope to be helpful.
Voeg je antwoord toe
jaylin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 5,563
