Ga door naar hoofdinhoud
Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Vragen Bekijk alle
Replacement Power button not pressing or clicking
Hi all,
My power button stopped clicking in - when you pressed against it the button never moved and didn't click.
I brought a new power button ribbon cable and replaced it.
When I put the button in and hold the bracket against it the button works and clicks, however as soon as I put 1 screw in the bracket the power button stops clicking and goes stiff again.
I have made sure the power button is in correctly, metal bracket down etc.
Ive tried 2 power ribbons now and they all click, just not when the bracket is screwed in.
What gives?
Thanks in advance
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
try backing the screw that holds the bracket out 1/2 turn to a full turn. Sometimes if they get tightened all the way down it will not click
Was dit antwoord nuttig?
Score 1
Try taking the back glass off, fold a small piece of paper and put it under the power button for a temporary fix.
Voeg je antwoord toe
Andrew zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 67
