Ga door naar hoofdinhoud
Guides for the LTE version of the iPad Mini 3. Announced on October 16, 2014, the iPad Mini 3 is the successor to the iPad Mini Retina (now known as the iPad mini 2).
31 Vragen Bekijk alle
Vraag afgerond
Does digitizer replacement require soldering?
Hello,
I cracked the digitizer on my iPad mini 3 recently and am looking at replacing it myself using ifixit's front panel digitizer and their iOpener kit. I was wondering if this process will include any type of soldering? I have researched and watched numerous repair videos and some say you do need to solder and some say you don't. The digitizer appears to have all the connectors pre-installed, so I'm really hoping that no soldering is involved. Can anyone confirm this?
Also any tips and advice for a successful repair would be greatly appreciated.
Thank you in advance!
Link to digitizer:
iPad mini 3 Screen Digitizer
iPad mini 3 Screen Digitizer Afbeelding
Product
$39.99
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi
No soldering is required if you buy the part with the Home Button IC module pre-soldered (slightly more expensive but well worth the time saved!)
The link you posted to the digitizer appears to have the Home Button IC pre-soldered so you should be all good to go , no soldering required :)
Was dit antwoord nuttig?
Score 1
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 867
