Ga door naar hoofdinhoud
2.26 or 2.4 GHz / White plastic unibody enclosure
645 Vragen Bekijk alle
Vraag afgerond
Not reading internal hard drive
My Macbook isn't reading my internal hard drive. I changed the hard drive and tested it on an external hard drive reader, so I know it's not the hard drive itself. I also changed the hard drive cable. Still no luck. How do I repair this problem?
Is dit een goede vraag?
2 opmerkingen
How did you format it?
door
I formatted it correctly. Mac extended journal.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
The hard drive may not be backward compatible with your machine. Please give us the make and model number of the new drive.
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
PNY:
Available: 214.9 GB (214,904,344,576 bytes)
Capacity: 239.71 GB (239,713,435,648 bytes)
Mount Point: /
File System: Journaled HFS+
Writable: Yes
Ignore Ownership: No
BSD Name: disk0s2
Volume UUID: E8B538D0-C15F-3586-8673-69902693DDBB
Physical Drive:
Media Name: ASMedia AS2115 Media
Protocol: USB
Internal: No
Partition Map Type: GPT (GUID Partition Table)
S.M.A.R.T. Status: Not Supported
This is the type of hard drive I have
door
Hard drive works from an external drive, so this isn't the problem.
door
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 184
