Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
20 Vragen Bekijk alle
iPhone 5s Completely dead - won't charge or turn on
Hello, I've got a customers iPhone 5 bought in for a screen & battery replacement which won't turn on at all. It wouldn't turn on even BEFORE I attempted to repair anything.
She states that it was working with poor battery life before she gave it to me. I trust her.
I did the usual, Hard Reset, Removing & Replacing the battery, trying with a different screen. However the phone doesn't respond to anything, I don't feel any vibrations with the mute switch.
Usually when it comes to this I remove the battery and plug in the phone, this usually flashes the Apple logo, however it won't work this time.
Is removing the battery a valid test? Could replacing the battery still work? ( I don't have stock at the moment, it's coming next week)
Any other ideas?
Is dit een goede vraag?
Score 54
51 opmerkingen
Popped in an iPhone 5C Battery, the phone powered on no problems however it wouldn't charge, probably the port then since I did clean the debris out.
door
I have just changed battery in my I phone 5 It work for a bit charges up then just gose off so got new battery and it did the same thing any help any please
door
my iphone 5 suddenly dead.
connect itunes and restore then workes my iphone 5
door
it could be the charge port? i am going to try this now
door
my iPhone 5 won't turn on . but when it did I had to keep it on the charger . if I took it off it will turn off . even restarting my phone won't work . sometimes the apple logo will appear , then disappear . can i get a solution please .
door
46 commentaren meer tonen
Voeg een opmerking toe
12 Antwoorden
Gekozen oplossing
Put iPhone Into DFU Mode
In some situations, your iPhone may not turn on because it won't boot up. This can happen after jailbreaking or when you try to install an iOS update without enough battery life. If you're facing this problem, put your phone into DFU mode this way:
Plug your iPhone into your computer
Hold down the on/off button for 3 seconds, then let it go
Hold down the on/off button and Home button together for about 10 seconds
Release the on/off button, but keep holding the Home button for about 5 seconds
If the screen stays black and nothing appears, you're in DFU Mode. Follow the onscreen instructions in iTunes.
Was dit antwoord nuttig?
Score 88
34 opmerkingen:
if not complete then just press Hold down the on/off button for 3 seconds, then let it go and charge your iPhone
and its ok
door
ok so i did this but i mesed it up and did the button inputs incorrectly, but now its charging so yeah..... at least its doing something and not just being a blank pile of crap
door
This looks to be the solution. Battery would show that it was charging, but would not build a charge large enough to allow the phone to power up. DFU seems to be working. Thx !!
door
I did this third time and still nothing is working. :(
door
in itunes it shows waiting for iphone and in last it shows error4005
door
29 commentaren meer tonen
Try holding down the power button and the home button at the same time on your iPhone until the Apple logo appears on the screen.
Score 17
11 opmerkingen:
Thank you bro. You nailed it! It works on my unit.
door
oh wow, I thought I was going to have to buy a new phone. Thanks a bunch!!
door
thanks!!! It started working!
door
Thank you very much,It works!
door
Worked, Thanks
door
If you're doing repair a lot, a "known good housing" is invaluable for troubleshooting. In a no power iPhone, you need to differentiate No Charge from No Boot. Inspect for water damage.
If the phone will boot but won't charge with a known good battery and a known good dock, then consider U2 chip failure on the board.
Score 8
2 opmerkingen:
i have exactly the same problem, i changed battery and phone started fine but iam afraid that if this battery drain completely the phone will not start again. But after battery change phone work fine and charging fine
door
I tried to Connect my iphone on my PC but still my iphone 5s is not turning on or the apple logo wont showed up but the computer reads my iphone and i tried to restore and update and all i got is an error, how to fix this? please give me any idea how to fix this thank you.
door
If ur IPhone is creating same problem like Turning off automatically, at anytime & reopens after hours then dude there's no need to be worry about your money and for your close to heart IPhone, lol !! Do follow these below steps
1- Your IPhone should have atleast charged or should plugged in .
2- Push down your Ringer button to Silent mode, i.e just push the button down in silent . (its weird but worth)
3- Press then hold your IPhone's power on/off button and Home button both at same time and for not just 10-14 sec. , hold them both untill Apple logo appears but don't hold for more than 1 minute
4- If doing above 3rd step your Iphone doesn't opens then friend don't worry do 3rd step simultaneously until and unless u see Apple logo .
And u can believe on this trick because friend when I was having IPhone 5s, I captured same problem and the only above solution made my IPhone to work as before, and tell u last thing this problem isn't temporary, ur IPhone will go dead several times but now u don't need to wait for it to reopen automatically
Just do the simple above trick
Hope u get ur solution
Score 6
2 opmerkingen:
thnx so much. Thought my phone was gone
door
i tried this and everything else i read and my phone still isnt turning on :(
door
When you plug in the charger without a battery connected, the iPhone starts normally, maybe the problem is in the flex charger lightning.
I finish to repair a IPhone 5 that would not start, I try doing the "hard reset" the final problem was the power button flex and battery. If the power button does not work you do not get to do the hard reset, but you can do it, holding down the home button, and connect the charger "USB connected to the computer" in this way enters restoration ele mode.
If not, the problem is in the charger lightning flex, try a new, and try to power the iPhone, if it does not work, try changing every flex? Perhaps one is giving a short circuit on the motherboard.
If not, then the problem is on the motherboard, you'll have to find some qualms technician for motherboard.
Score 3
It's simple. The device in most cases is fine. Apple collects (through an algorithm) how often a user buys apple devices. After your time's up the device will gradually self-destruct through intricate pre-loaded bugs or updates to encourage new purchase. And guess what they all buy again anyway and they know it. The new apple products' life expectancy is about a year in most cases. Try turning off the device (or let it run out), remove it from your icloud online. Use a different wifi, icloud, sim card, and computer in a month to reboot. Otherwise free urself and buy a nokia, vertu, huwaei, samsung or any other non-slaving brands.
Score 3
4 opmerkingen:
I used an old iPhone 5, >4 years, not really a programmed obsolescence ! My iPhone 4s is still working, but a little bit slow for certain app. Your comment is just your opinion, not a fact. Not useful on a forum like here.
door
I am an engineer and all machines and electronic devices have a lifetime. We people have a lifetime and the whole Universum have a lifetime. iPhones have also a lifetime average about 4 Jahrs (some of them a lifetime 1 or 2 Jahrs and some of them 3 or 4 or 5 Jahrs but average 4 Jahrs) that's normal. Of cause smartphones companies can do a better quality of smartphones but if they do that the price of smartphones will increase and the companies will not sell so many smartphones. so what they do is not so bad and not so good quality (something in the middle).
door
My daughter in law is having same trouble so I went searching online and found this forum, I'm actually leaving a comment to say thank you for the advice and tell R Ck rep 37. That I loved his comment. Classic. I feel the the same way about Apple. They have way too much control over those phones, just like how easy it is to by a iPhone and have it turn out to be a paper weight when you find out it's locked.. ( I didn't let that one settle to easy, let's just say I ended up with a working phone in the end) but you were dead on with your comment. I own an Android now
door
Good luck with that. Most android phone makers don't do any OS updates, Google does, but then only for 3 years.
door
step 1: hold power button and home button then apple logo on screen few minute wait done
step 2: plug in charger cable
step 3: insert new battery and check
step 3; connect itunes and restore
Score 2
Connect to iTunes and then press home and power button, computer will make a noise that USB has been connected and suddenly Apple logo will appear in iPhone and it will turn on. It worked for me. I hope it helped a lot.
Score 2
Try to open your simcard, and then do the hard restart to your iphone. If ur iphone on, turn off again and sigin in ur simcard again. Hopefully thats way can work, cause i just try to my iphone and work. My iphone has blue screen and wont turn on at all, after more than 12 hours. Good luck
Score 1
i had/have this problem too! I really don't want to reset my phone with DFU and stuff because i don't want iOS 10 either but i still wanted to have iOS 9.3.3. So i tried instead to just hold down the power button for like 20s or more and then the charging icon showed on screen until i released the button. So then i plugged my phone into charging in the wall and held down the power button again for like 20s and now i think it has started charging... idk if my phone did this just because of jailbreak but you can try atleast
Score 1
1 Opmerking:
worked for me ! Thank you
door
Same exact thing happened to my 5s, it would not power on or do anything, not even showing charge iPhone message. Tried putting it in DFU mode, nothing, I changed the battery and broken screen and it powered up onto the lock screen.
The iphone 5 is plug on charger cable but it won’t charge and there was a few time I was able get working but my sister phone is jacked up real bad.
Voeg je antwoord toe
Giovanni Joubert zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 48
Afgelopen 30 dagen: 165
Altijd: 694,943
