Ga door naar hoofdinhoud
The LG Voyager is an Internet-enabled multimedia phone designed by LG Electronics and on the Verizon Wireless network, Telus, and Bell Mobility.
4 Vragen Bekijk alle
Vraag afgerond
phone will not ring for incoming calls
Phone does not ring for incoming calls. I get ringtones for voicemail and texts, but not for incoming calls. I have checked ringtone and it rings loud, but nothing for incoming. I have it on vibrate too, but that only works if it is in my pocket. I have gone through all of the tool settings and modes. I can't find anything wrong.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
It has happened to me with my iPhone. I found that i had my phone under "sleep mode"…. Not sure where your sleep mode may be at on your phone, but might be worth a try… Hope this helps.
Was dit antwoord nuttig?
1 Opmerking:
Thank you. I will check that
door
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 130
