Ga door naar hoofdinhoud
The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
730 Vragen Bekijk alle
Vraag afgerond
No sim card displayed after repair
I have a GSM iPad 2 and I'm trying to repair it. I work in a repair store, and after changing the screen and the SIM card try it is still showing "no sim". I don't know if there is another part that needs to be replaced but I can't figure it out.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
I have had this issue and I noticed that the little metal tab in bottom of the tray that grounds out when the sim is inserted is bent and I had to shim a small piece of paper between the two pieces and it fixed it. I hope this helps.
Was dit antwoord nuttig?
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 99
