Ga door naar hoofdinhoud
De Turtle Beach Ear Force XO Seven, uitgebracht in de zomer van 2013. Modelnummer: TB300-2219-01. Compatibel met de Xbox One en mobiele platforms. Het uit elkaar halen van de headset is relatief eenvoudig en beginners zouden geen problemen moeten ondervinden.
How can I stop right side creaking
Is there a quick and easy solution to stopping the right side rotator of the headset from creaking? The persistent creak is near unbearable, yet the left side in silent. Is there anything that I can spray in the joint or something because I'm just about ready to go buy a new headset.
Is dit een goede vraag?
Score 4
2 opmerkingen
anyone come with a solution to this problem??
Thanks.
door
i fixed mine buy getting a set of hyperx core. i will never own turtle beach again
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
my XO seven was making a lot of noice in all the movable joints , i used wd 40 to lubricate the joins.
do 1 joint at the time , spray the joint , have a rag or paper towel to whipe of the any spills , move the joint and keep whiping , move on to the next , after all joints are done make shure there is no spills .
this will remove most creaking and noices from the joints.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
You lovely being. I didn't even think of WD40, I used oil first. Which didn't work at all. I bought the Arctis Pro Gamedac a couple of days ago and of course I was pretty !#^&@@ when my 230€ headset started creaking all of a sudden.
WD40 fixed it. I had totally forgotten about having that stuff. Thanks a ton !
door
Hey Mike, I’m having the same issue with my headset. The hinge that connects the ear muff makes a creaking sound and there’s another lil hinge that is connected so you can rotate the ear muff up and down and the other hinge you can move side to side so they can lay flat if they are resting around your neck. How long did the WD-40 trick last for?. Thanks for the help.
door
Voeg je antwoord toe
Troy Schuster zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 14
Altijd: 6,181
