Ga door naar hoofdinhoud
Announced in March 2015 and released April 10, 2015, the Galaxy S6 Edge is the curved-screen version of Samsung's newest flagship smartphone.
237 Vragen Bekijk alle
Can I get samsung s6 edge to come out of ODIN MODE?
My phone will not switch on. I have tried to press the volume up + power + home key and also volume down + power + home key. My phone only goes to a blue page which says 'warning.. A customised os can corrupt your phone etc...' and 'press up to download' or 'down key to cancel and restart phone'. When I press down key my phone does not restart, just turns off and will not power back up. If I press the volume up key it will turn to a page saying downloading and will stay stuck on this page for hours. I have tried a number of combinations but nothing has worked. I cannot plug into a computer or go into samsung as I am on vacation on an island. I also cannot pull the battery out as I have a s6 edge and if I do unscrew it will void my warranty. Can anyone please help?
Is dit een goede vraag?
Score 24
12 opmerkingen
after hard reset my device goes into odin mode and restart what i do
door
I press down key my phone does not restart, just turns off and will not power back up. If I press the volume up key .
door
My phone will not switch on. I have tried to press the volume up + power + home key and also volume down + power + home key. My phone only goes to a blue page which says 'warning.. A customised os can corrupt your phone etc...' and 'press up to download' or 'down key to cancel and restart phone'. When I press down key my phone does not restart, just turns off and will not power back up. If I press the volume up key .
door
whay if i disable usb seeting on my phone then also the reset factory and the laucher of the phone and its system UI shut down automatically ..how can i fix this please help me.. :(
door
maybe my chace is on with ODIN mode but don't how .. please help me lol
door
7 commentaren meer tonen
Voeg een opmerking toe
12 Antwoorden
Gekozen oplossing
Press all buttons at the same time and hold them.
Was dit antwoord nuttig?
Score 154
58 opmerkingen:
Thank you mine was stuck in this mode and I'm fairly new to the android world and this saved my butt majorly!!!
door
love you brother thanx a ton
door
Wow thanks man
door
thanks man, saved me
door
worked for me nice one dude
door
53 commentaren meer tonen
Just hold all the Buttons on the same time power button volume up volume down and home button
Score 22
1 Opmerking:
my power button is stuck and doesn't work
door
get into download mode then hold volume down, power home and the phone should power off. If it won't power back on try holding power and volume down for like 20 sec, it may boot normally.
Boot into recovery power volume up and home and try clearing cache partition (wont delete your files)
then in recovery try factory date reset (will delete your files)
finally if all else fails flash the stock rom (make sure same version or newer than you are using can't go back) using odin
Score 10
2 opmerkingen:
THANK YOU SOO MUCH BUDDY !!
You saved my device ! i was worried BADLY ! I was trying to install new firmware on my android ;/ thanks anyways buddy :) God Bless you :)
door
vol up+vol down+power+home not work for me, power+home also not and if i go to vol up or down+home+power phone goes to Odin mode, i need to factory reset coz i forgot lock pattern. please help if possible.
door
Hold Power + Home 15 seconds (Hard reset)
Hold Voume Up + Power + Home until recovery boots.
If this doesn't boot recovery mode and your phone is stock and untouched take it back to Samsung.
If you've flashed CFW/repaired it you're going to have to put it into download mode (like you were stuck on) and flash OFW via Odin.,
Score 6
1 Opmerking:
You are like God for me you saved me from my parents as I do this is mistake
door
Thanks a ton. Verified! It Works! Press all the buttons Vol up + Vol Down + Home + Power and hold them!
Score 6
2 opmerkingen:
Thank you sir
it s work. do it Valium UP and Down , home , and power key for five seconds . its work. thank god and thank you
door
It worked for me. Thank you so much :)
door
https://www.youtube.com/watch?v=bii27UQY...
Score 3
1 Opmerking:
When I do all 3 it go to maintenance boot mode
door
Try this.
Press and hold together "power button + volume up + volume down + home button" for about 1 minute and your phone will reboot to nomal.
Score 3
4 opmerkingen:
When mine reboots it is in another language. How do I change this??
door
Thank you sir
door
Its not working for me
door
Hi, sorry for late reply guys.
Sometimes it takes more time and need to press and hold for about 1 minute.
If this does not work then wait for your battery to drain completely or bring it to your local technician.
door
ive got a samsug j6 can someone tell me how to fix it
Score 1
I yanked the battery out of my Note 2 when it did that. Then opened up Safe Mode by holding volume down as it powered up and removed some files that possibly were corrupt
3 opmerkingen:
I yanked the battery out of my Note 2 Then restarted my phone in Safe Mode and uninstalled some apps I downloaded from Google Play that had embedded malware and its been ok since.
door
can anybody help me please?
door
i was trying to download iodine apps for my samsung galaxy s6edge plus but i cant download it
door
So sometime this type of situations occurred. Just Install a firmware to your phone. Flash with Odin. But it may reset your phone!!!. After you phone will work properly. Be sure a right firm to your phone. 100% guaranteed. If you have any or queries. Please email me at vineil91@gmail.com. Best of luck... :) :) :)
1 Opmerking:
Hi i cant get any of the above to work?help pls
door
I know this board is old, but I'm having this problem but none of these options work. I can get to the blue downloading screen, but when I push the button combinations on that screen it just goes black and does not boot up.
3 opmerkingen:
So does mine do you know how to fix it?
door
I had to repeat the process a few times before the volume down to restart phone option brought up the black and white Galaxy S6 screen to restart. However, now it keeps looping that screen and not actually rebooting. Keep at it!
door
Hold the power and home button together for 15 seconds
door
Still stuck. Tried every example that was given on this page. Took the pbone back to the Sprint store where it was originally purchased from only to find that the techs there didn't know how to fix it. So now, Im just sitting on a $800 device that won't power on.
Voeg je antwoord toe
hajera zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 29
Altijd: 178,635
