Ga door naar hoofdinhoud
The tenth generation Corolla (E140/E150) was released in Japan in October 2006. A narrow variant was available in Japan while wider versions were sold internationally.
23 Vragen Bekijk alle
cranks but does not start, suspect immobilizer, how to repair?
car cranks but wont start, found mouse cut the wires inside dashboard. this wire seems connected to TDS. please help me solve the case.
thanks.
Basudev.
Is dit een goede vraag?
Score 4
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
probably security system wires were cut by mouse which either disconnected your fuel motor power or current being supplied to spark plugs
if these two things are fine then you must check Camshaft position sensor & Crankshaft position sensor for malfunction
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Bashudev zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 739
