Ga door naar hoofdinhoud
Model A1224 / Early 2009 / 2.66 GHz Core 2 Duo processor
102 Vragen Bekijk alle
Why my iMac does not Turn ON?
I have been using my imac for a year.
Yesterday I tried to turn on the machine without any success.
I only hear a short noise if I have my ear in the side of the optical drive and after that a fan working (low noise). Nothing else after that, the screen remains off.
There is only one green LED at the lower part of the iMac.
The only way to turn off the fan is by forcing a shut down with the power button.
The aforementioned LED remains off after shutdown.
I removed the power cable, check the source voltage, tried another outlet without any luck.
Help please. Thanks
Is dit een goede vraag?
Score 1
2 opmerkingen
+ well asked
door
Do you know where I can find the Power supply and the Part Number? (I am assuming that the logic control board is OK)
Thanks for your help.:-)
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi, Here is a link to another answer that explains the LEDs. Based on what I see I think you may have a power supply problem. Good luck.
LED power supply and logic board tests
Was dit antwoord nuttig?
Score 1
1 Opmerking:
+ nice link ;-)
door
Voeg je antwoord toe
JRD zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 5,138
