Ga door naar hoofdinhoud
The original Xbox is Microsoft's first widely popular video gaming system. It has an easily identifiable black case with 'XBOX' emblazoned on the top and front. Repair is easy with common tools.
170 Vragen Bekijk alle
Original XBOX - No video signal but has sound
Hi,
We recently got our old Xbox out of the attic to play some older games. We have changed TVs a lot since it was last used and have found we are having problems.
We can get sound but no video. One TV we can plug the AV cables in directly and the other using a SCART converter. We are not very technical and have no idea what else to try.
Thank you!
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
did you try putting the yellow video wire into the green hole? some tv have 6 holes. green red blue are the hd av cords then there are 3 other ones yellow/video red/sound right? and then white sound left? so put in white to white and red to audio red. then yellow to the green hole of the hd av hole. hopes this helps.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
poppynchomp zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 12
Altijd: 3,149
