Ga door naar hoofdinhoud
Model A1369, 1.6, 1.7, or 1.8 GHz Processor, 64, 128 or 256GB Flash Storage
328 Vragen Bekijk alle
Need to wiggle power adapter to get MB to charge.
My computer is 4 years old. Love it. But it's had a lot of use. Regardless of the power supply and cable, I sometimes need to wiggle the connector to get the red charging light to come on. I think that I may need to replace the magnetic connector and whatever it is connected to. Is that easy enough to do? and what do I order?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Do what John said. I use a wooden tooth pick to make sure the retractable pins on the adapter are coming all the way out. Use a Q-tip soaked in alcohol and clean the receptacle on the machine. A good quality single malt Scotch will work fine. I prefer mine neat with a single cube of crystal clear ice chipped off a block. As long as I use it to clean with, it becomes tax deductible.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
You sir, are a scholar and a gentleman.
door
Het nuttigste antwoord
Look inside at your pins - there a 5 of them look for one loose or pressed in I personally when the charger as been off for awhile use rubbing alcohol and a pin to free it then let it dry out.
Score 2
Voeg je antwoord toe
Marian zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 1,597
