Ga door naar hoofdinhoud
The Asus MeMO Pad 10 features a vibrant IPS display with a 1280 x 800 resolution.
Tablet keeps freezing up. can not power off.
Lately my Asus freezes up , unable to power off . having to use up battery until recharge, power up put it use for no more than 15 minutes then freeze.
Is dit een goede vraag?
Score 2
1 Opmerking
Screen keeps freezing
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Bachup all data.
Turn it off
Maybe you must use the reset trigger on the side
When it is turned off
Press volume up and hold it
And then push the Power button, while holding volume up
Hold till you see the Android with a helmet
Thats hatdreset
That may help
Everything will be erased
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
as karl5th said. I did the same and it works. Thank karl5th
door
Very helpful Thank you very much had same problem and it worked
door
let it cool a while a little bit
Voeg je antwoord toe
myriamlwebster zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 3,144
