Ga door naar hoofdinhoud
Handleidingen voor reparatie en demontage voor koelapparaten van levensmiddelen, waaronder koelkasten, diepvriezers en koel-vriescombinaties.
1699 Vragen Bekijk alle
Vraag afgerond
Refrigerator is leaking water inside but the drainage is not clogged
Maytag Performa Refrigerator Use and Care Guide - 61005299. I have cleaned the drainage tube and the refrigerator is tilted to the back. But the water freezed at the opening of the drainage and clogged the drainage. The water freeze and block draining tube. I turn off the refrigerator and melted all the ice in the freezer. But the water that comes form the freezer freeze again blocking the draining opening. Could anyone suggest what is the problem? Thank you.
Is dit een goede vraag?
1 Opmerking
There is a problem. This refrigerator does not have ice dispenser. It have the freezer at the top and the refrigerator under it. Could it be that is low on refrigerant and that is why is building ice on the evaporator? Thank you.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Check to see that the flapper door to the ice dispenser is closing completely.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Ice build up on the coils is a sign of low refrigerant.
door
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 611
