Ga door naar hoofdinhoud
The Sega CD I, A.K.A. The Mega CD I (in Japan) was the original Sega CD unit released in 1991.
5 Vragen Bekijk alle
My Mega CD1 won't read Game CD, but can play audio CD.
Hello. My Mega CD1 won't read Game CD but audio CD play without problem.
The CD-ROM icon never appaeared in the menu.
Is this an optic problem and supposed to be tuned or is there problem in other parts?
Thank you in advance.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
adityarai2001, sounds like an issue with the laser. I would try to clean the laser with a professional clean kit first. You can also disassemble it by using these guides and clean it. If that does not work you most likely will have to try to replace the laser assembly.
Was dit antwoord nuttig?
Score 1
If you have a multimeter check the ohms of the laser should be at 700 ohms or .700 k ohms make sure not to adjust the Focus pots
Voeg je antwoord toe
adityarai2001 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 10
Altijd: 935
