Ga door naar hoofdinhoud
Ondersteuning voor golfkarren op gas en elektrisch, soms golfkarretjes of 'club cars' genoemd naar het merk Club Car Golf Cart.
1998 electric club car golf cart rear brakes locking up
My husband and I purchased a used 1998 electric club car golf cart and when you step on the brake the rear brakes grab real bad. It almost throws you through the windshield. The man we bought it from (very trustworthy friend) said he had just had the brakes replaced not long before we bought it. When this happens with the brakes, it kicks the brake pedal back up. Do we just need to adjust them or could there be something else going on. My husband and the mechanic we always use for our cars are at their wits end.
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Het nuttigste antwoord
Check for axle twist especially if the cart has a lift kit. Check to see if the U Bolts are tight they often loosen and just need retightened .
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Check for rear axle twist especially on a cart that has been lifted. The U Bolts loosen up and allow the rear axle to roll adding additional pull on the brake cables when the brakes are applied.
door
How does the rear axle “twist" and how do u fix it?
door
If it has a lift kit try tightening the U bolts Mine were loose and fixed it
Voeg je antwoord toe
Cathy zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 36
Altijd: 6,592
