Ga door naar hoofdinhoud
Repair guides and support for smartphones in the Curve line produced by BlackBerry since 2007.
69 Vragen Bekijk alle
My BlackBerry Curve 9320 phone is not getting started...
my phone is not geeting started after software upgrdation ...
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
I had the same issue and fixed it with a hairdryer! Try taking out the battery, blow drying it for a little while on all sides. Then blow dry the keys of the phone and inside where the battery goes. I don't know why it worked but it did. I assume there was either dust blocking connections, or some moisture causing issues.
Was dit antwoord nuttig?
hello Hari Saladi ,
it is very easy to fix your phone. case is the firmware not update properly
Use this line to download JL commander
  • install jl commander
  • connect your blackberry to pc via USB cable
  • select option 5 (reset to factory defaults)
  • your phone will be restart and hangs with error on white screen
  • install blackberry desktop manager using this link
  • update software gain
after updating the software you can use your blackberry with better performance ever !
Voeg je antwoord toe
Hari Saladi zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 414
