Ga door naar hoofdinhoud
Reparatiegidsen voor de MacBook Air, de huidige lijn consumentenlaptops van Apple.
4820 Vragen Bekijk alle
Vraag afgerond
MacBook air not turning on
hi, i bought on macbook air a1466, the seller told me that it has black screen of death fault, i opened it and checked that one i connect charger to it, first there is green light, then it changes to orange and it does not turns on, when charger is connected,the fan runs for few seconds and then it turns off and charger light changes to orange, i have tried smc reset, pram reset also, but it doesn't work.
is there any way i can repair it
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Replace motherboard, that's the option bcos it's probably a processor failure from the motherboard
Was dit antwoord nuttig?
This does sound like a logic board fault but it is actually very difficult to confirm other than by elimination. It can be normal for the fan to momentarily spin when the power is connected to the machine and before the machine it turned on. It could simply be that the signal from the power button is not reaching the logic board. Every logic board has power-on solder pads that can be used to manually power not he machine by shorting them. You would have to Google where these are on your specific model, but this can rule out a faulty power button.
Disconnecting anything non-essential helps eliminate other components like the Airport/bluetooth board & battery.
Beyond that, the only way to be sure is either to replace the logic board or get your logic board fitted to an identical model MacBook Air that works but this is obviously not practical for most people.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 716
