Ga door naar hoofdinhoud
Repair and disassembly guides for Lexmark printers.
it not printing any documents
Hi,
My lexmark priter model X2550 is not printing any thing. it is scanning.
just the its not printing.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Hey Dev, try what I wrote below or reinstall the drivers on your computer for your certain computer.
-I found this from a support website:
Disconnect the device from the computer, reboot, reinstall the Lexmark software, when prompted by the software connect the printer to the computer.
Also, if you're getting certain error codes, here are what they mean.
-Let me know how it goes.
-Please accept this as the answer if it answered the question.
Was dit antwoord nuttig?
Score 1
If Printer not print anything thn there is problem with cartridge or may be printhead then you have to check it or replace it carefully if you find any kind of defects in it and fix the issue.
OR
If you are facing any kind of problem with your Printer like paper jam, Cartridge Issue, Driver Installation, Print not print anything and much more then no need to worry get instant help from
If you facing any issues regarding Samsung Printer you can call on Samsung printer customer service Tollfree>> 1-866-877-0191.
Voeg je antwoord toe
Dev zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 10
Altijd: 370
