Ga door naar hoofdinhoud
De Xbox draadloze controller 7MN-0001, vervaardigd door Microsoft Corporation, is de meest gebruikte controller voor Xbox-spelcomputers en kan ook in combinatie met pc's worden gebruikt.
127 Vragen Bekijk alle
Why is my controller over heating, and not vibrating?
I found that after a month or so after buying the Call of Duty Xbox One. That the controller that it came with began to over heat and not vibrate. I also have found that the plug and play rechargeable battery that I use loses power very fast as well in this controller, but does not in the controller it came with. I have tried doing a firm ware update with it, and followed all of Microsoft's troubleshooting tips but nothing has helped. It says to send it back to them but I would like to fix the problem on my own.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
The wire from the vibrating motor probably came loose and is now touching other things in the controller causing the problem.
Was dit antwoord nuttig?
If your Xbox One Wireless Controller no longer vibrates when it’s supposed to, see the Xbox One Wireless Controller Won’t Vibrate problem page for possible problems and solutions.
Voeg je antwoord toe
siebener zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 4
Altijd: 1,035
